CA_Traveler
May 15, 2019Explorer III
I'm also suspicious that the batteries aren't fully charged. By far the best way to determine charge is to measure the SG which takes the guesswork out of a voltage check.
The graph apparently shows a 4A load for 5 hours or 20Ah with batteries that are likely rated at 200Ah+ and the voltage is very low with that small load still attached. That's only a 10% discharge. Perhaps the bad terminal is a factor.
But stop the guesswork and check the SG after charging and at the end of the load test.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
