rbts's avatar
rbts
Doing an electrical system from scratch, need some help!
Hey everyone! I joined this forum specifically to ask this question and I hope someone here can help me figure it out.
My wife and I purchased a used 2011 Forest River R-Pod with the intention of doing a light remodel (paint and replacing vinyl floor) and it is now a down-to-the-studs remodel after finding water damage in the floor and walls that wasn't noticeable until the floor was removed.
Anyway, since I have the opportunity to put whatever I want into an empty shell of a camper, I'm doing everything from scratch with new components since the original systems looked awful, maintenance heavy and childishly wired in my opinion. We're going for a low energy solar/shore power setup thats as maintenance free as possible.
I've done literal days of research now and think I have it all figured out except for one detail. Without specifications (since I've only decided on one component), here's what I've planned:
Solar panels (wattage TBD)
Solar charge controller
Spartan Power 2200w inverter/charger (also includes a transfer switch): ***Link Removed***
AGM batteries (probably two 6V, haven't calculated my needs yet).
What I'm stuck on is probably the simplest part of the setup, the distribution panel. Initially I had trouble because I didn't even know the right keywords to search for, and could only find residential sized breaker panels.
The problem I'm having now is that I can find extremely few options that DON'T include a converter/charger. Correct me if I'm wrong, but I don't think I'll be needing one with the inverter/charger I've chosen as our camper will be connected to the 30amp shore power for the majority of our trips.
I've currently found these two that I think complete the system, providing a DC panel and an AC panel in compact form without also adding in a converter/charger:
***Link Removed***
***Link Removed***
Will either of these work to complete the system, am I missing something, or is there a better product I should be looking for?
    This being the case why go to the expense of installing solar, a controller, double GC-2s, an inverter, and a transfer switch? :h
    I think you have this backward. You don't need a large inverter/charger/solar if you will be mostly plugged in.
    Get an RV electric panel with converter and go camping a bit. Get two batteries for one or two nights off grid but save yourself the inverter/solar until you decide to go mostly off-grid.
    www.bestconverter.com/PD4045-45-Amp-Inteli-Power-Mighty-Mini-Power-Center
  • rbts wrote:
    I don't think I can link to them as a new member, sorry!
    Just post the raw url and see if that works.
  • New members unfortunately can't post links until a few other posts are made (for spam prevention/remediation), so I can't tell which units you're thinking of.
    The Progressive Dynamics PD5000 panel or the Parallalax 80D panel would both be perfectly reasonable choices. Bestconverter sells them (and they're good and helpful people to deal with, and quite knowledgable about RV power systems).
    It's also reasonable to have separate AC and DC distribution panels if that ends up suiting your installation better. DC fuse panels in just about any size and shape and description are quite easy to find. Small AC panels that are not wired for 240V split phase use are harder to find. In some cases, it might be possible to safely tie the two legs together via main lugs or similar...or just to ignore one of the legs, or something. I suspect you already understand this, but the 120V panel in an RV should keep the ground and neutral independent, like a sub-panel in a house (but unlike the main panel where they are bonded together).
  • You need to use the -Advanced Post Form- to post links. Use the link icon (looks like a blue circle with some chain at the bottom) to post a link.
  • The distribution panel links were to:
    Progressive Dynamics PD5000 Series AC/DC Power Distribution Panel – 30 Amp, 120 VAC
    WFCO WF-8930/50 Distribution Panel
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
