dougrainer
Sep 25, 2020Nomad
RLS7201 wrote:dougrainer wrote:theoldwizard1 wrote:BB_TX wrote:
Suburban and Atwood have both proven to be very good and highly reliable water heaters.
Good to get positive feedback !
My daughter's Attwood never has run right since the first day the bought their Jayco. It would light once, but almost never re-light until you cycled the power switch. 3 trips back to the dealer and over $100 out of pocket for "igniter adjustment" and they gave up. If they want hot water, they have to keep cycling the power switch.
Very strange.
Your dealer is incompetent. Plain and Simple. IF a Service Center has a problem with an appliance, the FIRST thing they do, is CALL the Appliance Maker and explain the problem They will walk the Tech thru various tests. IF after the tests and any replacement parts do not fix the problem they may authorize a new replacement appliance. After 41 years as a RV tech, I have found that the younger RV tech crowd(and so called supervisors) seems to think CALLING for help is not the way to go. Well, I have better ways to make my money than wasting my time trying all sorts of tests. I refuse to just replace a part unless directed by the Appliance maker after all tests are done. By calling the appliance maker, you may find out that the appliance has a known fault with a part. Not published yet. As to your Daughters Atwood(Dometic now), you don't state what year model. BUT, there is a KNOWN problem with the Atwood Water Heater Ignition modules starting about 3 years ago and ending about 1 year ago. They had hundreds of thousands of defective Ignition modules and purged what they could. Doug
Or.......your problem could be an issue with your primary thermostat. If it fails and your heater shuts off on the Emergency Cut Off (ECO) thermostat, the circuit board will lock out and not let the heater refire until you shut off the heater and turn it back on. It's a known issue.
Richard
NOT a "known" issue. I have never experianced a 180 degree lockout and then tried to see if the WH would relight without cycling the wall switch. IF the ECO trips at 180 degrees you WILL get the POP OFF valve weeping, which is usually an indication of primary tstat failure. As long as the air cavity is still in the tank. Doug
