sayoung
Jan 15, 2019Explorer
dougrainer wrote:
The Main Control board is what determines the length of Defrost. Once the Sensor indicates it needs the defrost cycle, the control board then starts the sequence and stops it. Doug
The control board should also have a max defrost time limit . I have never serviced a rv heat pump but on residential/commercial units the defrost sensor should be mounted on the outside coil ( condenser ) as it gets cold in heating mode, 15 to 20 degrees below ambient temperature.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
