Agree with Capacitor First. If the Capacitor is bad, the Compressor will draw LRA (Locked Rotor Amps) like a stuck one.
Your brand MAY use a two-way capacitor. A Fan terminal, a Compressor terminal (likely marked HERM for Hermetically sealed system), and COM, Common, probably between the other two.
IF that's so, and FAN runs, you only need to buy a single capacitor with the higher of the two uF (maybe marked MFD) values, 35 in Fred's example. Just ask for a jumper to connect the COM of the two-way to one terminal of your new one and of course move HERM to the other terminal.
So you may find only one "can" in there. If you find a tall, round, plastic capacitor, a third one, let us know.
