Good morning from Az, 3 way propane side issue. Could it be?? DOMETIC 2007199009 RV REFRIGERATOR COMBO THERMOSTAT I'm hoping this is the problem, when on propane and either #1 or Highest setting the...
Most 3 way Dometic refers have a BYPASS Tstat for the LP temp control. That means when calling for cooling the flame is HIGH(Normal). When it reaches temp the LP pressure is bypassed and the flame lowers to a small enough flame to not cause cooling. So , you probably have either a defective LP tstat or the Tstat wire is not secured to the Evap fins on the inside of the refer. Doug
