dougrainer
Jul 22, 2018Nomad
1. Burping CANNOT dislodge the blockage. It is as hard as a weld and attached like a weld. I tell customers, if you had a blockage in your Arteries and you were able to "knock" it loose, would you be happy knowing that debris is now flowing thru your blood system. Where it will eventually block something else? Then you die?:B
2. Rebuilt cooling units, they cut out the top area tubing to remove the blockage, weld a new tube in place and then charge with Ammonia. Rebuilts are the way to go if you do the work yourself. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
