Gene_Ginny
Jun 18, 2013Explorer
Use alcohol to clean the gas jet then blow it out with compressed air. The jet will unscrew from the burner body with a small socket wrench ... I forget which size. I did use alcohol on a Q-tip to clean the burner tube (the part you see the flame) but usually it only needs some compressed air.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
