evergladesgator
Jun 19, 2013Explorer
Similar problem by me and others.
evergladesgator wrote:
BUT, from my experience with thermocouples if the TC was defective, the gas valve would not open and if it did open it would only be for a few seconds NOT minutes like what mine is doing.
I had two TCs fail (over a 20 year period), and like you, my experience was that if the TC was defective, the gas valve would not open and if it did open it would only be for a few seconds NOT minutes. When it failed for the third time, I had symptoms more like you had, but perhaps more randomly. It would die after an hour or so, then perhaps after 10 minutes, then run for 2 hours, etc. My flame looked good and I'd adjusted the TC to the right point, and when I replaced the TC the problem continued.
D Mitchell Y'all need to recheck your model number or hope for Chris to check in..
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
