dougrainer
Jul 26, 2020Nomad
Garry&Gayle wrote:
I got this from Dometic Tech, and its also in the Dometic Technical manual; to do a reset turn off refer the cut all power 12V and 110V for a few seconds then turn on 110 and 12V turn on refer. the first defrost cycle will occur after 60 hours and then repeat every 48 hours there after.
Put the link for a DOMETIC. What you posted is for a NORCOLD. Dometic's have NO defrost cycle. Norcolds do. Doug (Dometic trained Tech for 41 years)
PS.the "only" reset is to turn the refer OFF for 10 seconds and back on after you have a check light come on from LP lack of flame
AND, There is NEVER any reason to remove 120 power to a Norcold or Dometic. The controls are ALL 12 volt.
