woodland_park's avatar
Jun 20, 2016
dometic 9100 electric just clicks
when I press the extend or retract switch, my Dometic awning just "clicks". If I hold the button in depending on the direction, I can manually roll up or un roll the awning. Bad motor? I have voltage either way at the awning connector. Thank you
  • SoundGuy wrote:
    dougrainer wrote:
    Bad Motor.
    The OP hasn't given any indication as to the age of his Dometic 9100 power awning but quite a few manufactured in 2013 were recalled ... perhaps the OP's is one of them.
    2013 Awning. looks like it falls in the recall s/n
  • dougrainer wrote:
    Bad Motor.
    Just follow Dometic's recommended procedure for manually retracting your power awning, as detailed in your 9100 Awning Owner's Manual.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
