Kpackpackkelley
Jun 04, 2018Explorer II
enblethen wrote:
I would start by checking all the connections. Inspect, disconnect and re-terminate all the wiring in 120 volt distribution panel and transfer switch. Pay special attention to the neutrals in the back portion of the distribution center. Get some electrical de-oxidation grease. Coat the bare conductors prior to terminating. Look for melted insulation and burnt conductors
Genset is running a little too fast which is causing the higher then normal frequency.
Thanks that’s where we usually set the no load hz but I know what you mean. I’ll start with the connections. Thanks it’s kind of a weird one.
