dougrainer
Jun 30, 2018Nomad
1. You cannot test for voltage with a Multimeter at those pins. You have to use a 60 watt light bulb in a socket with 2 wires to test for voltage.
2. On the control board there is a black relay. The is a BLACK wire and a BLUE wire(12 gauge). With NO 120 connected to the AC, jump those 2 wires together and then supply power to the AC. IF the compressor starts and runs, either you COLD(comp) wire from the wall tstat is not sending the signal or your control board is indeed bad.
3. Also, with NO POWER to the AC, take the WIRE CAP off the compressor and verify that all 3 wires are intact and not burned. Do this FIRST before item 2 is done. Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
