beaubeau wrote:
Hi!
Last night, in this configuration, the fan turned off. I can cycle through Au, to Hi, back to Lo and the fan will come on, but still will turn off after a while.
Also, separately, I think ... I had the temperature set at 68 but the air temperature is 70. Nothing is running. So I lowered the temperature to 64, still nothing is running.
Not what I read, and on my unit at night on low fan in the bed room with the temp set low the whole unit turns off and it get hot. Then you must cycle thermostat off then back on. At somepoint it will do the same thing on low...no issues on high.
