Learjet wrote:
... with the temp set low the whole unit turns off and it get hot. Then you must cycle thermostat off then back on. At somepoint it will do the same thing on low...no issues on high.
That sounds more like my symptom where the whole unit turns off and won't recycle back on until you "power cycle" the thermostat. Except I don't know about it not happening on HI fan. I run mine on AUTO which makes it downspeed to the LO fan before cutting off when the thermostat gets satisfied.
Doug - if beaubeau's motor is over heating, then why can he reset it by turning the AC off, then back on? Maybe because there has been some time lapse in that sequence for it to cool? It would be interesting for him to try "power cycling" it immediately to see if it will come back on...
