jfschmitter1's avatar
jfschmitter1
Dometic AC in auto mode
I am having a problem with the new AC since I installed it about a month ago. It is a Dometic 15K AC with a new LCD Thermostat kit. This is a ducted system. When running in Auto, the fan will start and run for about a minute but the compressor does not start. This will occur 2 or 3 times and then the compressor will start. This problem normally occurs only at night. I live in Kissimmee FL, so the temperature is in the low to mid 70’s at night. If I lower the thermostat 1 degree after the fans comes on, the compressor will start immediately. I have tried another new thermostat and control box and still get the same result.I changed the freeze sensor. Added additional foam insulation between the air inlet and outlet. Monitored the voltages at night and did not find any changes.
Please let me know if you had any suggestions.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 29, 2025
