fred42's avatar
fred42
Dometic AC replacement grille very fragile
One of my Dometic AC grilles had the tab break off. I ordered this one:
https://www.amazon.com/Dometic-3104928-019-Polar-Ducted-Grille/dp/B00RHSEYG4/ref=cm_cr_arp_d_product_top?ie=UTF8
Somehow, it installed OK, but the first time I had to change the filter both tabs broke off and the grill broke in the middle. The plastic is extremely brittle, perhaps it was a bad batch. The comments have several users having them break, sometimes on the first installation.
I hesitate to keep buying these, has anyone had better luck with a different source? I think I could make one out of some aluminum grille material. My previous Coleman units never had this problem.
thanks very much,
  • One tab broke off over a year ago, so I tried crazy glue (don't know what brand) to hold it together. Removed cover several times to clean filter and it's still holding.
  • Both taps also broke off on mine, I use those little twist ties to hold the grill up in place now.
  • Mine broke in my second year and never use ac ...just checked filter once and bankgo..both tabs broke.
    Put screws in to hold grill and perfect.
