esfd243's avatar
esfd243
Dometic AC
We are set up at FW and our 2016 Hemisphere has dual ac units. The main coach is controlled by the thermostat. When its warm out like right now the ac cycles every 2 or 3 minutes and turns back on after about 2 or 3 seconds. Sometimes on high sometimes low. At night it cycles as it should. Not sure what's up?
1 Reply
  • Mine cycles between hi and low speed when in auto fan mode. I finally just switched it to Hi fan and left it there. I've seen lots of folks posting of the same issue but never saw a post that mentioned a fix other than switching the fan to either hi or low and leaving it. Of course the compressor will still cycle as it should.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
