Cartwrk
Oct 06, 2020Explorer
Dometic Atwood gc10-4e hot water heater overheating
A few months ago we had a new Dometic Atwood gc10-4e 10 gallon gas/electric hot water heater installed. After installation we discovered that the electric wasn't working. The mobile repair guy wouldn't get back to us so we just used the propane for a few months, which worked fine. Yesterday we had some work done at an rv shop and they got the electric working, which we set to be the heating method overnight (propane was turned off so we were using electric only). The next morning the hot water heater was steaming and water coming out of the release valve. The plumbers putty on its water connections was warm and soft enough to come off easily on your finger. Water coming out of the faucet measured 150+ degrees.
I'm trying to understand what has happened here - it seems like when using electric for the first time on this relatively new hot water heater that the thermostat ran too hot or something. I have read online of people having the circuit boards fail with this particular model but I'm not sure that would cause this particular problem.
If I could figure out how, I'd just as soon fix this myself by following instructions or a youtube video, but I don't have a lot of experience in the area and I'm not sure where to start or what to replace. At the moment I'm not even sure if it's safe to just go back to propane only because I don't want to inadvertently make things worse.
Any input is appreciated.
