Fisherman
May 22, 2022Explorer
Q. Does the pin go all the way to the other side and is visible? You may be able to tap it out with a brass punch if you can figure out a way to support the end piece, or, some tool like a ball joint remover or big wide opening "C" clamp pushing in a smaller item to push the pin out the other side. Good luck.
