Dan_East
May 23, 2022Explorer
dougrainer wrote:
I understand what you are trying to do, but over the years I have seen various OEM awning makers different light wire designs and I can think of no good reason to do what you did to install a wire to allow the wire to roll up and down. I hope you post a pic of the final resulting install to let us understand the design of what you did. Doug
I'll post a picture when it's complete. Unfortunately bad weather has come in so I put the awning back together and rolled it up. At least I now have a simple bolt to remove to access what I need to access.
The problem is my LED lights are attached to the awning roller tube, which of course rotates as it rolls in and out. That means I either need to somehow run wires on the awning itself that roll up with it (which I don't want to do), or have a rotating style conductor (rotary connector). So I've designed a cheap rotary connector that I'm using, which needs to go around the shaft of the awning. Hence my need to remove the pin to have access to that 11 mm shaft.
I've 3D printed plastic bushings that go between a bearing and the shaft to insulate it and also connect the wire to the bearing. The bearing conducts positive power to the lights (the awning arms / tube itself are the ground connector), so it can rotate freely with no wires to twist, require unplugging, or have to somehow attach along the awning and roll up with it.
