dougrainer
May 23, 2022Nomad
I figured that is what you are trying to do. Hopefully it will work for sustained in and out use. LCI/Dometic/Carefree awning makers have had various OEM rotary type designs a few years ago and NONE worked for more than a year. So, they then realized it was just as good to have the LED lights mounted just under the sidewall mounted awning rail as that would give enough light as a LED light string in the tube 8 feet away. Doug
