Johno02
Oct 10, 2016Explorer
Should be OK to take the tension off by lowering the stop. The awning should latch in at the top when stowed. The purpose of the stop is to keep it the outer part from sliding down too far when the awning is extended and used in the ground leg position.. The stop also helps when the awing is being rolled, so that the roller is positioned correctly at the top.
