Hank_MI
Oct 10, 2016Explorer
That post does align the top of the arm with the bracket when closed. If it closes properly you should be good to go. What may have happened is the previous owner let the arm fall and hit the post when lowering the awning. Previous owner of our MH did that. I can see where the post is bent down slightly and paint is chipped off around it. There are 2 rubber bumpers on the outside edge of the top bracket. When the awning is closed the upper arm should rest against these bumpers.
