Chris_Bryant
Oct 12, 2016Explorer II
The bottom bracket must hold the entire weight of the awning, whether retracted or deployed. That shoulder bolt is a stop to keep the arm high enough that it fits over the top bracket.
IOW, As stated, the problem is the bottom bracket needs a sturdy attachment. That said, both stops should be installed so the awning is even when retracted, and if the bottom brackets are not even, the stop bolts should not be as well.
FWIW, the A&E 8500, 9000, and 8300 Sunchaser with nested hardware are functionally identical, but theoretically you need the exact hardware part number to match parts.
Looking at your pictures, I question the installation. The bottom bracket should be in to the floor line, or a reinforced area. It should never be simply screwed to a sidewall with no backing.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
