Hank_MI
Oct 12, 2016Explorer
solar07 wrote:
SO, mayybe closing it right may solve my whole problem? I have seen a few videos but they are all a bit different. Any suggestions on a good one?
From there, I need to ask, should the sliding arm rest on that shoulder/set screw at all when closed?
Yes it should set on that screw. That's it's purpose, to adjust the height so the upper arm goes above the lip of the upper bracket and closes tight against it. If you look you see there are multiple holes int the lower arm so the shoulder screw can be set at the correct height to hold the arm up.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
