dougrainer
Nov 02, 2015Nomad
1. Nobody will repair under warranty. They will only replace the unit under warranty.
2. You will need a Dometic authorized Service center Tech to verify and call Dometic to see if they will cover it. Probably Not, but with the pic they may bend the rules a little.
3. If it was mine and they denied warranty, I would solder the hole, solder in a Schrader valve (NEVER use a clamp on fill valve) and fill the system. uses about 1 lb of 410.
4. This will not be a quick replacement if the approve warranty. It will take about 2 to 5 days depending on how soon the Dometic Tech calls them. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
