time2roll
Jul 13, 2016Nomad
2000 is marginal (13.3 amp rated) and may work fine. Yamaha 2400 might be a better fit.
Make sure the choice is compatible with an extended run fuel tank that I assume you need.
The actual draw is probably a bit less than the max rating.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
