dougrainer
Mar 07, 2019Nomad
His symptoms are classic for a partially blocked cooling unit. This happens over years when you ran the refer off level occasionally and you never notice the degradation of cooling until you need it to operate at 100 percent when it is warm/hot outside. Since it does the same on 120 and LP, he probably has a partially blocked cooling unit. Doug
