dougrainer
Mar 07, 2019Nomad
WesternHorizon wrote:dougrainer wrote:
His symptoms are classic for a partially blocked cooling unit. This happens over years when you ran the refer off level occasionally and you never notice the degradation of cooling until you need it to operate at 100 percent when it is warm/hot outside. Since it does the same on 120 and LP, he probably has a partially blocked cooling unit. Doug
Quite possible. I don't think the unit was boondocked much for the first 19 years. I boondock 95% of the time and have done about 400 nights in 5 years. That's close to 10000 hrs operation.
I am very careful to level but still cumulative damage could have occurred.
As you note, this would explain all symptoms.
If you want to test the refer for partially blocked---Put a cup of water inside the empty refer. Run the refer 24 hours on 120 by hooking up the 120 element direct to 120 volts. After 24 hours measure the temp of the water. If NOT below 32 to 34 degrees you have a partially blocked Cooling Unit. If Partially blocked, Doing any other things to get better cooling is a waste of time. If it is partially blocked no big deal, it still functions, just not at its best. Doug
