dougrainer
Apr 15, 2015Nomad
LOOK at the Burner flue cover. You will see a small round Thermal Snap disc with 2 red wires going to it. IF that snap disc has failed, you will not have 12 volts to the control board of the refer. There should be 12 volt positive on BOTH wires at the snap disc. If one has 12 volts and the other does NOT, then the snap disc needs replaced. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
