mjdaspen3
Oct 25, 2015Explorer
Hi folks. I realize this post is several months old, but I have a similar problem and I'm wondering if anyone can help. If the fridge goes into lockout, will the interior light stop working as well as the fridge itself?
I brought the trailer home from the park to prepare it for winter. I parked it on an angle so I could repair a drain pipe underneath, and I plugged the cord into the garage outlet to keep the fridge working. I noticed at one point the check light was on the fridge, but not knowing the check light was only to indicate the LP mode failed to ignite, I assumed it was on because the trailer was on an angle and couldn't cool properly. When I was done my repair I unplugged the trailer, parked in on a level surface and plugged it in. Now the fridge seems to have no power at all, not even the interior light works. The only things I have verified is there is 120vac at the plugin, and 13vdc at the terminal strip. Any ideas? Thanks
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
