etki84
Aug 28, 2023Explorer
enblethen wrote:
OP you said you have power to board but also said it got thrown away. Which is it?
You could apply power directly to the 120-volt element. It should start cooling the refer if it is good.
Good chance that the 120-volt relay on board has or had failed.
I tested the plug that plugs into the eyebrow board, that is how i know there is power coming from the bottom board to the top, the bottom board is new. from what i can tell the top board is a simple two button board with just two led lights. There should be a way to jump the top plug to make the unit come on.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
