JPG77373
Apr 28, 2018Explorer
Dometic DM2852
I am running out of options trying to fix our Dometic 2852 fridge. The problem is that it tries to run on propane when it is plugged in. First I checked power all the way to the board, meter is ...
wrgrs50s wrote:
I had the exact same issue and replaced the lower circuit board with a Dinosaur board and still same problem with only working on propane.
I purchased a new eyebrow board on amazon and problem solved. Works perfect now.
