- wasatchmtnatvrExplorerfront frame 2 lower screws into wall below refer, seen by opening refer door all the way. 2 top screws buy removing optical panel above freezer door . into wall above refer. Also indicated 2 at rear (exterior) vent removed into legs and maybe 1 or 2 more if recall metal installed.
- Ex-TechExplorerScrews around the front frame and two at the bottom through the frame in the back.
You will also most likely need to remove the propane line.
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 22, 2025
