arcsum68
Jul 28, 2020Explorer
Its been VERY well tuned up, multiple times. It has been pulled multiple times and brought to a shop, no small feat when you are on a lake and have to move it to a ski boat. It's had all the recall work done to it. Every person that goes out there with any mechanical background has done it, including me. At this point it must be the cleanest burner ever because it never gets used, not worth the effort most of the time.
We stopped even trying to use ice packs to get it cool because it does not hold and we are just wasting our time. It can be on for 5 days and the freezer is still the only thing worth anything, at BEST it will get to the 48 degrees if the weather is just right and the genny is on a lot.
The Norcold in my Nash would freeze the fridge out if we had it turned up all the way.
I honestly do not think its a burner/chimney issue. I have fiddled with the adjuster on the fins in the refer section and even put a fan in there to circulate the air. Could it be anything else or does it all boil down to the cooling unit?
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
