shastagary
Jul 28, 2020Explorer
if it actually worked good on the test bench then you may suspect the installation and proper parameters of the venting and how close it is mounted to the outside wall to get a proper cooling chimney effect.
is one of the vents on the cabin roof or are they both on the side wall?
the manual describes the parameters dometic rm 3600
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
