dougrainer
Aug 29, 2021Nomad
What you state does NOT make sense. The freezer is the FIRST part of the cooling unit coil and is NOT controlled by the refer Tstat. But, lets see if you have the correct way of determining the actual temp.
1. Glass of water in the lower section after 24 hours, what is the DIGITAL thermometer temp?
2. What is the Freezer temp with the digital thermometer?
They don't die from age. They either fail from running too many times off level or the Ammonia leaks out from a crack/hole in the tubing.
Are you the Original owner? Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
