dougrainer
Aug 29, 2021Nomad
The Dometic recall had nothing to do with operation of the cooling. It was a add on safety device for the LP section. The BEST way to determine function of your refer is to hot wire the 120 element for 24 hours and then take the temp measurements. They should be below 35 degrees in the lower refer and 0 to 10 degrees in the Freezer. From your post, it appears the Cooling unit is bad. Until you do the 120 element hot wire, you will not be certain. EVERY RV'er needs 2 things. Doug
1. A Digital Multimeter
2. A Digital Thermometer
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
