fastartcee
Jul 13, 2016Explorer
I would like to double check wire connections I've made at the terminal block. (Sorta dumb... but I didn't make a sketch before disconnecting.)
I have two black wires connected through the terminal block to a black wire. I have two white wires connected through the terminal block to a white wire.
Are these connections correct?
(I have an image of the wiring diagram from the installation manual, but I don't see how to attach or insert it into this message. The diagram implies black-to-black and white-to-white connections.)
I've got myself into a time jam, and could really use a bit of help. Thanks.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
