labradorian70's avatar
May 20, 2013
dometic fridge intermittent
hello
im new to this forum and brand new to RVing. Bought a 2011 keystone Bullet Premier 28ft TT last fall and made my 3rd trip with in this past weekend.
The fridge is a Dometic and has only 2 buttons on the top, one ON/OFF button and one Auto/Gas button. We had it set to AUTO all weekend.
spend 3 days in it and noticed the fridge was acting funny......here's a little time line.
I hooked up the camper to the truck (friday) and turned on the fridge at the same time so it would be cold or well on it's way when we got to the camp ground 2 hrs later.
Got to camp ground, Set the fridge to AUTO, TT was plugged into 30A shore power, propane tanks were on and plenty of propane.
friday night fridge was cooling as it should, noticed saturday morning fridge was not cooling, check light was NOT on. I cycled the on/off button and auto/gas button and noticed the fridge did start getting cold again?
Put some ice cubes trays in freezer saturday afternoon with water, sunday evening the cubes were only Half frozen. Woke up monday morning(today) and cubes were completely melted, fridge was warm again. still no CHECK light
So in summary....
1. I checked breakers and fuses. all ok.
2. Fridge was set to auto.
3. Propane was on and full.
4. Shore power was connected
5. Water heater and furnace working fine on propane.
6. Everything else in trailer appears to be working.
What else should I be checking, fridge seems to start up and work but then seems to just stop and the "CHECK" light does not come on.
I know the CHECK lite works because when you first press the on button for the fridge all lights(AUTO AND CHECK) come on just for a second as a test.
I have contacted the RV Dealer with the issue today and waiting for a response but in the meanwhile and possibly save a 2hr drive to the dealer I thought I would check in here to get some ideas.
What else should I check, or does it sound like a bad fridge?
cheers and thanks.... I can get a model for the fridge if anyone needs it. It's 30min away at my mother in laws farm.
Glen
  • labradorian70 wrote:
    is it still an issue with the newer ones.
    no. Within comfortable living specs is level enough.
  • I did use a level when I parked to get it level. How many degrees out of level will cause problems to a fridge. I didn't get it perfectly level but darn close. I know this was an issue with older fridges but is it still an issue with the newer ones.
    Cheers
  • Was it level when parked? This is the biggest killer of absorption fridges.
