dreamco
Jan 23, 2016Explorer
wrgrs50s wrote:
I had this problem and traced down where the 120volt power cord plugged in to the circuit board and found that the spade connection was not pushed all the way on to the circuit board. I pressed on the spade and heard and felt a little snap and then I had power to the heater rod and then it worked on electric.
If you find that the connections on the circuit board are tight and clean, the fuses are good, but no power is going out to the heater rod when the selector inside is on auto and plugged in to shore power, it may be likely that the circuit board itself may be bad.
If voltage is going out to the heater rod but it is not heating, you will need to unplug the heater rod at the circuit board and use a volt ohm meter set to ohms and check the heater for a short. It should read around 41 ohms. If not the heater rod will need to be replaced.
If the circuit board is suspect, take it out and to a repair facility that has a circuit board tester to determine if it is in fact bad before purchasing a new board. Dinosaur is the board of choice for a replacement.
Thanks for the very detailed post.
Is the circuit board you're referring to concealed in the black box located in the lower left of the photo below?
Thanks again for the help!
