- Old-BiscuitExplorer III
Norskeman wrote:
Looks like the question was answered:
Research indicated the thermistor location set at the factory is usually the on the last fin on the right as you look at the reefer. Move it up for cooler and down for warmer. IF you move it, move it in small, small increments and allow 24 hrs. for the reefer to adjust temperature in relation to the move of the thermistor. Takes 24 hrs. for temp to stabilize.
The right side of the cooling fins, as viewed from the front of the fridge are the coldest, therefore moving the sensor a fin or 2 to the left may help those whose reefers are NOT cold enough.
........PROVIDED the fridge has a pre-set temp control vs one that can be adjusted via upper panel temp selector - NorskemanExplorerLooks like the question was answered:
- JC2Explorer
Old-Biscuit wrote:
The thermistor should be inserted n plastic clip with tip just protruding from top.
Plastic clip then goes on far right fin ....mid position
Temp adjustments are done via upper panel temp selector button
Thank you. That's what I thought. - Old-BiscuitExplorer IIIThe thermistor should be inserted n plastic clip with tip just protruding from top.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
