Display panel lights, interior light etc....ALL 12V DC
Electric doesn't use the 'check light'---that is only a function of propane side
If you have fridge in AUTO it will select AC as priority
No AC available it will swap to 'gas'...if gas fails to light/prove 'Check' Light comes on
In AUTO and fridge remains on AC the AC power is available, AC Fuse on circuit board is good BUT electric element is bad cause no cooling is happening
OR the cooling unit has fail (blockage)
If thermistor/preset thermostat fail then fridge goes into LIMP Mode....CONTINUOUS cooling which will freeze both freezer and food compartment
Sounds more like the electric element has failed
325W element.....44 ohms....2.7A when energized
