jkwilson wrote:
motc777 wrote:
This thing ran all night long and all day long on electric. I just got home and while still cold I noticed that the pipe on the outside cover is not as hot as it was. It’s lukewarm and the coils on the back of fridge are cold. The frost on the fins has gone away too. It’s like it’s not working again.
I read that if it work son propane but not on electricity then likely it’s the element. But I literally just replaced that a few days ago. Did I get a bad element? Is there some other problem?
Turning the heat on and off is how the refrigerator controls the temperature, so if the refrigerator thinks it is cold the element may not be hot.
An easy check is to make a short cord with blade terminals on the end to apply power directly to the element. The unit will run wide open and probably ice up. If it gets really cold after a day running like that, the element and cooling unit are fine.
OK, not to be thick, but just double confirming. So when running on AC, it is normal for the heating element to cool down and warm up depending on if the fridge thinks it cold or hot?
I have a new thermistor that I haven't installed yet. Should I just go ahead and do that? Mind you, prior to all this ****, both the freezer and the fridge would ice up bad, but since replacing the heating element, hasn't happened at all.
