rvman69
Jun 11, 2023Explorer
The thermal unit seems to be tight to the metal cover.The wires are tight on the unit.The stack seems to be clean. I would have to take it apart to look at burner pipe. Right? I am going to try to put a pic on here so you can see what you think. I did notice it seems like the top of the stack is not clipped in like the bottom is. It looks like it should be clipped in like the bottom. Should I take the stack apart some to see if there is any yellow junk in there? Thanks
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
