JBarca
Jun 12, 2023Nomad II
Here are some pics of an actual failed RM2652 as a comparison
NOTE: This fridge had the recall done to it.
The fridge was removed and underwent dismantling for repair.
Your pics do not show the normal heavy yellow. But, look up where the gas burner and the flame goes up the flue tube to see if there is yellow residue in that area.
Also, your 1999 RM2652 does not appear to have the recall done. I do not see the heat shield of the other thermal fuse. There is still an active recall on this model fridge. Check your fridge serial number in this Dometic recall link. https://www.dometic.com/en-us/outdoor/lp/refrigerator-recall
If yours is in the recall, contact any authorized Dometic repair place; they should be able to do this. Since so much time has passed, they may have to order the recall kit, and it may take a few months to make this if Dometic is out of them.
Hope this helps
John
Hope this helps
John
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
