JBarca
Jun 12, 2023Nomad II
You replaced the fridge, ok that explains why you have only the one thermal disk switch on the stack and no heat shields and the thermal fuse behind the burner stack.
Yes, just check the serial number.
I have seen just the one thermal disk switches show up on RM2652’s made in 2006. It may have been they tired a partial fix to layer find out they needed the entire recall kit. They extended the recall to include newer models. It is explained in the Dometic link.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
