dougrainer
Jun 12, 2023Nomad
rvman69 wrote:
Ok so I just hook the two leads from the heating element to an extension cord. Does it matter how the leads are hooked up polarity wise? Do I leave the refrigerator off or does it need to be turned on? I will test the baffle with a stiff wire and see if I can get anything out of it and if it rattles. Then I will blow it out with air compressor. Then I will hook it up to extension cord. I will wait until in the morning so I can be around it for several hours after I hook it up. Is there anything I need to really watch for while it is hooked up. Thanks
Polarity does NOT matter. You do NOT have to be around for the 24 hours. Use a cup of water in the lower section and take the temp from the water. Wiring direct bypasses ALL refer controls. Refer can be off or no 12 volt power to it. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
