dougrainer
Jun 13, 2023Nomad
rvman69 wrote:
So I guess I should be able to determine fairly quickly if the unit is at least circulating. All of the circulating coils should start warming up. Is this correct? If the circulating coils do not start getting warm after a while then it would mean that either the stuff inside has leaked out or there is a clog in the system. If that is the case there would be no reason to leave it on 24 hours. Is my assumptions correct? I guess then it would be time to order a cooling unit. I hope I dont have to but you have to have a fridge.
There is NO danger to running on 120 for 24 hours. This is what I do when I suspect a bad cooling unit. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
